Resolved transmission fluid mixing?
Samurai Jack
44
Sep 10, 2003
Can u mix 2 different kinds of tranny fluid???? I ran out of some and cant get the same type to fully fill it. Thanks
Well no you shouldn't do this.
Use ATF+3 or Mitsubishi Diamond SP or SPII fluid.
If not available then use Dexron III with a conversion fluid like Lubegard Platnimum or Heartland T-3 that will make the DEXRON III match the original lubrication factors as the Factory fluid!
(Mitsubishi Diamond SP)
Do this step as a last resort if you can't find the fluid you need.:thumb:
