Transmission/clutch problem?
Bobble
35
Feb 12, 2012
St Petersburg, Florida
So two nights ago I was at a friends house and I was drinking and I passed out but my car was blocking someone's so they decided it was a good idea to take the keys out of my pocket and move my car. And i have a stage two clutch in my car so its a little different than most clutches. I don't know what happened but when I woke up to go out to my car there was a whining noise that sounded almost like a belt but it only got louder with speed and not rpms. However it went away after getting after third gear. Also the clutch felt really weak. Than today I go out of my car to go to work and the whining noise is back and my clutch is completely gone. I can't shift out of any of my gears. So I don't know what happened exactly but to me it's pretty obvious that its the clutch that's the problem. But what exactly is the problem? Also could the two sounds be related? And what happened to cause this?
It was soft like I said the first night than today it was even more soft and just had almost 0 resistance
it may not be the clutch itself. check to see if you busted a clutch line. or that your master and slaves are working fine... it takes alot for a normal person to destroy a upgraded clutch. and unless your my wife its not gonna happen over night. my bet is hydrolics
