trans mount probs..
thrdtryGSX
100
Feb 21, 2006
Whitefish, Montana
I just had my motor out because my oil pump pully came loose and went out, so I removed the balance shafts and replaced seals and pumps. My problem is..I cannot get the second bolt into the trans. The rest of the mounts are started but still hand-tight. I can move everything around but it will not stay aligned. Does anybody know the easy way to get it started? I have tried to jack up the trans and everything.
i had the same problem more less when i pit my motor in. i could get one bolt started but not the second. so i dropthe the tanny all the way down and started the first bolt in the tranny( one closest to fender) then hoisted the tranny back to the position it needs to be in one the mount and then put in the second one. hope this helps if it does give me some reputaion points
