tranny help
xxsupralvrxx
259
Aug 30, 2007
Daytona Beach, Florida
ok well my car seems get more and more subbern on not wantin to go ino 1st and 2nd once and a while. When i put it into first it stays their but just trying to get the shifter into first can be a real pain...now Ive been told it cant a shift fork but...idk any help please?
check your gear fluid and your slave cylinder along with anything with the clutch and shifter bushings
yes I put the pedal all the way to the floor...this isnt my first 5 spd. LOL I was also wondering if it was the cables because it started to do this in my Supercharged Cobalt before the cable broke ( the original owner be up the caobalt bad..) O and this might sound really bad but can anyone tell me where to check the fluid at? and also how do I check the slave cyilinder? If it was the syncros wouldnt it pop out of gear?
Just to be on the safe side buy some gear lube, and change the fluid, their are to plugs for your tranny. One is on the front side of the tranny(to fill) and the other is on the passenger side(to drain). Drain it out then fill it up with the new till it starts to over flow out the fill hole. There is no dipstick for the 5speed.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
