tranny help
1speedyeclipse
May 4, 2004
Roseville, Minnesota
ok so the tranny blew on my 92 eclipse n/t. i found a good deal on an good condition tranny, and i figure its gonna be a lot cheaper if i buy it and do the swap myself rather than having someone rebuild and install mine. anyway, my question is, the tranny i found was from a turbo eclipse, will it still work if i put it in mine? btw i have a 6 bolt if it helps
thanks for any help
im doin this swap as we speak. heres what you need to get ti to work
youll lose some low end accel from ths swap i hope you know. gst has a higher gear ratio then the n/t gears. the gears are taller in the gst
you need:
gst fwd turbo tranny
gst flywheel or aftermarket oen for a gst
gst clutch throout bearing.
if its a auto you need the torque converter and all that jaz but you get the idea. just get some badass mods and let the power make up for the loss of lowend.
