tranny fill plug is a bunch of BS! (warning foul language)
99GreenEyeZ
Mar 10, 2009
charlotte/huntersville, North Carolina
THIS IS A MOTHER ####ING BUNCH OF BULLSHIT! WHOS ####ING GREAT IDEA WAS IT TO MAKE THE ####ING FILL PLUG RUBBER! ive reserched this shit and no one said anything about how to get this damn rubber piece of shit out. it just ####ing spins and spins and spins, i tried pulling/prying mother ####er is just in there. and then on top of all this mother ####ing bull shit i cant even post in the damn 420a drivetrain section ### im a newbie...####in bs. ive been a member of the 3g forum since damn 2005 and post there like hell but here, nooo. will someone please help.
99 gs 420a m/t. (using haynes manual) pulled the damn drain plug and nothing came out, (correct plug according to haynes) so i just want to get this fill plug out so i can check the level on it, how does come out. :cry:
The easiest way to do it is the bottom bolt off the plate over the bearing, you have to use a vacuum pump. And i lit my haynes manual on fire and watched it burn, chilton ftw
ill give it a go. thanx
edit: keeping haynes manual tho, worked well on my roomies 3g
just wait til you get into the electrical, never again. even though strangely enough my chilton manual is made by haynes?
Make sure u use the correct tranny fluid..Had a mechanic change mine and he put regular gear lube, needles to say 1 month later he was replacing trans for me(for free)..Started to chatter and whine after a 25 mile trip...
Never really had a electrical problem of course both my N/T were RS..Did have the oil sending unit go bad had oil everywhere. Got one from Dodge dealership 80.00 compared to the Mitsu Dealership 175.00 (order)....
yea, used royal purple synchromax tranny fluid, thanx for the help toxicity, worked like a charm, good thing the old man left his vacuum pump with me. ### i could see how that shit would be a pain without
