Tranny does not want to shift....
drivercrazy23
63
Feb 11, 2004
Brownfield, Texas
I just bought a 94 eclipse rs. The engine is the 1.8l with a automatic tranny. The problem I am having with the car is that the trans does not want to shift smoothly or go into first when you stop. The trans in the car is from a 91 rs with the same 1.8l motor. I was wondering if i needed to switch computers from the 94 to the 91, but my knowledge of the 1.8l engine and trans is very limited. If any of you guys know how to fix my problem please, all advice is welcome.
Thanks
Wes
Try checking the motor and trans mounts. If the tranny has any flex when the clutch slave cylender is pushing on the fork then it will not fully disengage. Also try adjusting the clutch petal as they have a tendancy to go out in the 1g. This assumes the clutch and everything is in good order.
good luck
good luck
Not everyone has a manual.
  • Wanted 6 bolt NT water pipe
    • chrisman287
