traction help??
xxsupralvrxx
259
Aug 30, 2007
Daytona Beach, Florida
I have a 1g Fwd is their anything I can do or get other than da radials or slicks...? I relize a lsd will change alot but.
Any of these would help:
-Drag radials,,Slicks
-Lower tire pressure
-LSD/welded diff.
-Coilovers,,
-Springs/Shocks
-Dual stage boost controller
-Learn how to launch better/Slip the clutch off the line/don't peg it off the start.
-LSD/welded diff.
-Coilovers,,
-Springs/Shocks
* - Swap over to AWD *
My edit to above. :D
All jokes aside try a real low dump to the point in which it bogs down a bit (Hold gas steady, release clutch, once car is moving feather in the gas), this will slow you down a bit but will gain you traction off the line at least or till you hit boost)
You could also swap over to the AWD axle setup (equal length).
Solid aluminum front and rear motor mounts made a night and day difference for me.
How bad is your vibration with both solid mounts?
There is definitely a strong vibration at idle. To the point that the dash makes a buzzing sound. But you get used to it.
The worst part is the clutch chatter at engagement which shakes the whole car (ACT 2600). But there is small "window" between releasing the clutch quickly and slipping it where the chatter is minimized.
Above 1200 RPM the car feels normal.
Bottom line, for me (especially being FWD) the benefits are so substantial that it is worth it.
I had the solid motor mount (front/rear) and Prothanes (drivers/transmission) and the vibrations are not bad at all. However, I just eliminated my balance shafts and with that combination, I've noticed a lot more "noises" from places there hadn't been rattles, vibrations, etc. before. But, the vibrations still aren't horrible and you get used to them in no time. As Romeen said, the benefits outweigh the minor annoyances.
But my rear view mirror is now useless :p
Yea?? you got any links to some? I never thought I would see the day when my talon sat like it is now because I got no lisence :( [screw tampa cops..mofos...]
As of right now I got another 6 bolt going together an i got a few mods :D 2g pistions, bc valve springs, an retainers, hahn racecraft 16g an its gonna be tunned on jackel :D
  • Wanted 6 bolt NT water pipe
    • chrisman287
