tps question
2GFWDbeast
1,094
15
Jan 17, 2010
kenosha, Wisconsin
i just hooked up the data logger and was checking some things out. TPS=10 does that sound rite for a 1g. Idle was bouncing back and forth from 970-1030, also iac was at 27
10%? Yeah that's fine, shouldn't read 0. The critical part isn't the TPS, it's the Idle Switch.
make sure your idle switch (other side of TB than the TPS with a single wire on it) is working. it should ground when the throttle is closed and be open when the throttle is open.
since you have a datalogger, are you able to read the voltage of the TPS? if so, it should be set at .63V when closed.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
