Toyota injectors fit?
l6u9k6e9
148
3
Jan 9, 2003
Dover AFB, Delaware
Hey i have a guy selling 310cc injectors for really cheap, they are off of a toyota would they fit? They are "toyota yellow top 310cc injectors"
also he has "mazda mx6/probe, escort, miata 310cc injectors" would those be a better fit?
as it would only run me 60 bucks it might be worth it.
also what is the size on stock 1g non turbo injectors? theres 2 over at teh junk yard and if there anywhere between 310-450's im there...
It depends on what they kind of Toyota they're from. This is a very general rule (so don't follow it exactly), but, injectors from factory turbo cars will work in other factory turbo cars, and injectors from non-factory turbo cars will work in non-factory turbo cars. Of course, they also need to physically fit and connect to the injector connections. If you want to mix and match you'll need to start adding things like resistor packs.
It all has to do with the impedance of the injector (saturated or peak and hold) and the voltage needed. If those two numbers for the injector and the car match, then you're set.
The only non-DSM injectors I know of being used in 2GNTs are the Ford "red tops." Given the number of Mazdas running on a Ford global platform of some sort, I would suspect the Mazda injectors would be a better choice, but I'm not an expert on this subject. I would only buy new injectors or those which information relating to fitment/use was readily available.
Maybe the link above will be of some use to you.
