Injectors that will fit
Shadow98
575
4
May 9, 2006
Columbia, Missouri
Ok, so there are plenty of threads out there asking what injector we can fit in our cars, but we flame most people asking because they do not have any kind of management... My buddy and I are trying something new on his 420A-T. He has a built motor and all supporting mods. Now, what injectors 660cc or bigger will be a direct fit and are high impedence? Don't worry about how we are controling them, I will post everything in a differant post later, after we get everything running correctly. :D
I'm running FIC 880's that I had in my AWD talon (1g). You have to work the 402a seals a little bit but they will fit. As well as the stocker 450's. BUT that is only talking about physically fitting in there. But I'm using a 4g63 ignitor with MSnS.
MB
MB: I'm not understanding what you're saying about using DSM injectors...
Edit: Since I don't have many responses, what injectors 500cc or bigger will drop in. If you can post a link as to where I could get them.
You're original question was what injectors fit. The DSM injectors will fit but you will have to use the 420a seals. When you use those seals, it is a bit difficult to get them in place properly, but they will work.
In addition, if you use those injectors, they are low impedance. You will have to have some sort of resistor pack set-up wired in so you can use them. I use the 4g63 ignitor as mine. Here is a link to give you an idea of the install;
Team 2GNT Forum - Viewing topic #776 - Mitsu 5 pin Ignitor wiring to run MS with spark
MB
