Torque converter bolts keep backing out
I fixed your thread title. Now, follow this rule:
Use proper spelling, grammar, and punctuation when posting in our Tech Forums - don't use texting/instant messaging lingo here. This isn't an English class, but we demand that you at least make an attempt or your posts will be deleted. Internet Explorer users should download IEspell or just use Firefox since it has spell check built-in.
Be sure to clean out the bolt holes with brake clean before installing bolts. If there is any paint from the converter being painted in the bolt holes it needs to be removed from the threads. Use red loctite and torque to at minimum 50 ft. lbs. Re-torque after the first heat cycle. The arp bolts give a lot of surface area to clamp down on, but you will have to take 1 or 2 threads off of the bolts. They are meant for a 700r4 torque converter and come in a 3 pack from jegs or summit racing. Kiggly has put together an awesome knowledge base from simple stuff to very in depth information about autos that can be found here
Kiggly Racing - kigglyracing.com
Best of luck!
Wade
