SolidBoostTSi
- 167
- 4
- Sep 27, 2004
Roundlake,
Illinois
Hey guys, I'm in a pickle right now only because I've got a brand new 18G(42lb per min) from FP that I haven't even put a mile on. The thing is I know I can run this turbo Hard in the 20-25 psi range on the track. But since I have PTE 780's I also know I can run a turbo as big as a 60-1(60lb per min <- like the name) at 15-20 psi. My question is Should I stick with the current setup or upgrade? Lag is not a problem (I actually like the anticipation of a big turbo) but since my displacement is only 2035cc's (.20) over stock and 8.5:1 compression I'm kind of discouraged from getting such a large turbo. I would appreciate all comments (pro/con) on this topic. I'f you need to see my vehicle profile, Please do so. I just updated it too.
Solid
Solid
It might be causing too much air drag. How do you see over it?
I'm not that desperate yet
