Topline Head Gasket
awd6boltsi
62
Jun 4, 2007
Belleville, IL, Illinois
I've got a new topline headgasket and I was wondering if I use copper gasket spray if this thing is gonna hold up to 20- 25psi with arp's or is it a junk gasket.
My friend's car was running 22psi on a 16g w/ a topline gasket + copper spray. We checked it out when we had the head off recently, everything looked fine. However, as Joe said, keep that knock in check and It'll hold.
Topline, partsdinsaur.com, fel-pro (fail-pro), oem, all have taken me to +45 lbs/min. ARP headstuds saved me from blowing the head gasket even with dangerously lean maf overrun. As 6-bolt owners, we have the luxury of WIDER diameter headbolts arp or not. That means our arp headstuds take ALOT more than our 7-bolt arp'ed counterparts.
Topline Head Gasket is a reboxed Felpro graphite head gasket. With Arp Head Studs you can handle 25PIS of boost as long as you keep knock in check. I have done it several times.
  • Wanted 6 bolt NT water pipe
    • chrisman287
