tons of smoke: head gasket, valve seals??
DoYuTurbo
34
Jun 12, 2004
mainville, Ohio
my 95 eclipse gst has 210k on it and i slowly started noticing little tiny puffes of smoke whenever i pressed the gas after a shift. then i got on it 1 day and it just started pooring white (and sometimes a little blue) smoke. also my turbo makes a wierd grinding noise at 3000 rpm right at spool up. any ideas the car runs perfect it just blows clouds. :(
Check your turbo....first.
If the seal is blwon you could be getting oil in to the intake and cooling + oil into the exhaust.
