Tokico Illumina
chris97pittman
242
May 10, 2004
Bellingham, Washington
I have tokico illumani shocks and they came on the car when i bought it and I know their adjustable but I don't know how to adjust them I know it has something to do with the little dials under the hood but I don't know what the different numbers mean and will it lower it? someone help please
I don't think it'll lower the car using the dial but 1 is for the softest setting and 5 is the stiffest so mess around and find out which setting best suit you........
See the thing is is I tried to mess with them but there were set on either 4 or 1 the little line goes all the way across so you don't know exactly and it twists all the way around so I really don't even know what one it's on..
Ah yes, everyone at first has trouble determining what setting they are on. The way to tell is you look at the line of the dial. Imagine the line of the dial (the spot where you insert your flat head screwdriver) to extend another 3" in both directions forming an imaginary line.
The Illumina settings are clicky. They will click into one of five positions. So you have one end of your imaginary line will "extend" through the little white line on the red cap. The other side of the imaginary line will be pointing to the setting you are on. Make sense?
yeah i was confused at first also. they do faintly click into each position so just play with it and when it clicks youll know which setting it's on
