fawkes
- 52
- 0
- Jun 26, 2004
warren,
Michigan
i was looking at the product pages on rebuilds and i was wondering what the stroker was and if it is worth the price anyone can help?
fawkes said:yeah it was like 500 dollars more for the price i got for the other rebuild kit
....do i need a diffrent block to buy a stroker kit? or do i use my stock dsm cause i know my motor is shot so i need to start this process
95GSXracer said:Too much BS with using a 2.4 block, IMO. Making holes, filling holes, etc... The only difference with the "2.3" is that the piston pin is in the oil ring, and the bore is a little smaller, depending on the over bore. If youre anal, go for it.
If you ask me, more important than getting the turbo spooled quicker is the extra ~20% air you can move at the same boost. This is pretty significant, especially on pump gas, and is often overlooked.
Mirage2LTurbo said:The guy above replied that his 50 trim was spooling 400-600rpm sooner on a 2.3 versus a 2.0. For street applications, this might be all fine and dandy. Lag is over rated, and with a competent driver, should never be an issue. A simple downshift will bring you instantly into boost with just about any turbo. If you are thinking about revving out your car, I'd stick with a 2.0. You might pick up some spool going with some more displacement, but I have yet to see a 2.3 or 2.4 rev over 8, while I'm taking my 2.0 to 9400.
