illwill
- 66
- 0
- Dec 16, 2002
ok.. the driver side front wheel while driving it sounds like something metal is loose and shaking.. someone said something about the bearing or something not sure.. but lets say if your sunroof is open and its loose and it squeeze when you drive.. thats the noise from the driver side tire.. 2nd.. i get a knock or thump noise from the passenger side.. i thought cv joint cause iv had to replace the boot once already but it looks fine.. my car was hit and bent the frame.. someone said something about the joint up in the tran's or something could be bad.. any help or ideas would be great.. also.. how much would it cost to replace the tire rods up front and both joints.. etc... thanks again
