tire problems
tbehling
133
May 23, 2003
my car is lowered with eibach springs after replacing the bald tires i bought the car with, i noticed that the passenger side rear tire is wearing really really bad on the inside edge, my first guess would be the camber... but... wouldn't the camber be the same as on the otherside? wouldn't that tire wear the same?, is there something that could be bent or broken causing this, and no the rim is not bent and the tire is balanced perfectly
WELCOME TO THE LOWERING CROWD!!!!!!!!!!!!!!!!!!!!!!!!!! I know where your comin from once you lower your car it changes EVERY geometrical formula for your tires caster, camber and alignment are all changed. Now maybe you you should update to poly bushings and check all your ball joint they might be worn out too. That happened to me but diefinitely your guna have to go and get it aligned for sure.
  • Wanted 6 bolt NT water pipe
    • chrisman287
