Tint
you donthave to cut it just right
cut it a little bigger then the window make sure to make it an inch or so longer then the window so u can slip it into the door/window area so when u roll the window down it wont get caught up
spray tthe window with water place the ting on - it will be very slippery so u can move the tint to the spot u want it i would suggest leaving some slop (1/8") or so extra around the entire window edges
slip the xtra inch of tint down the door
use the correct tool to "push" all the water out
carefully get a very sharp FILE and file off any edges hanging over the edges of the window
good luck thats only for the driver/passenger windows tho
