Timing Keeps Spiking
Assmatic
65
Apr 30, 2009
Wilton, Connecticut
After installing the MS-II, the car has had problems with the timing spiking, thus causing it to be un-able to be tuned
Is there anything you guys might think could be causing this? I'm going to go back and re-solder the connections and maybe add shielded wire in a couple places like the TPS, but before i do, has anyone else had this same problem and fixed it? or might anyone know what is causing it?
With accompanied tach spikes? Reroute the crank sensor wiring away from that of the ignition system and other high power leads.
Hmm well, the crank wiring im going to re-do with shielded wiring, but it's away from any high output except the alternator? which I can't help because the two are so close.
The grounding i have all the sensors grounded to one spot, and the ignition grounded to a seperate spot, i mite re-do the grounding connections a bit and try make them a little better though. Maybe that might work
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
