Timing help on a 420a with Crane Cams
stratatk01
Aug 30, 2012
Reedsburg, Wisconsin
Hello, I dont own a DSM but I do own a 3g Eclipse.
I was just looking for some information for a customers car I'am working on.
It is a 97 Eclipse N/T with a 420a (2.0 DOHC), short ram intake, header, egr delete and some exhaust work. He recently installed a Crane Cam and would like it to be dialed in a little better here are the stats on what he has done. Any kind of information or tips on what I can with the timing would be a great help.
AEM adjustable cam gears
Crane Cams: 264deg/256deg
.050 224 deg/216gross
.444/.424
2.2 Crank
Pistons: JE .040 overbore
Eagle H beam rods
Any information on what I can do would be a great help.
He also said his fans arent kicking on until it gets to about 210 degrees and would like them to come on sooner. He has changed to a colder thermostat would switching back to a hotter thermostat correct this issue? Or is there another trick that can be done?
Anyone?
  • Wanted 6 bolt NT water pipe
    • chrisman287
