Resolved timing belt questions
phillabaum03
849
3
Nov 28, 2005
sharpsville, Pennsylvania
ok..i did my first timing belt today and i lined up all the markers..when i had it tighted i spun the crank and took its around to tdc again and the oil pump gear wasnt on the mark unless i spun it like 3 times? is that how its supposed to be?
Solution
Sometimes it takes 6 full turns (to TDC) before all of the marks are lined up again. :thumb:
Solution
thats what i needed to know...thanks
also how do i know if its tight enough..i used a point to push the tension arm tighter..is that a bad idea? i know thats ###### not the correct way..
your supposed to use a tensioner tool, or you can make one using the battery hold down bolt.
DSMGSX95 said:
A word of warning.... proper belt tension is critical....
Couldn't have said it better myself. Back when I first got my car, I had a shop rebuild my head and do the timing belt for me, which was a bad idea because they decided not to adjust the tensioner pulley to the correct tension. They had it way too loose. $1700 down the drain and I had jumped timing and bent valves. So I did everything myself this time, the right way.
Do it once, do it right.
  • Wanted 6 bolt NT water pipe
    • chrisman287
