Timing belt auto tensioner!!!
brandon2gtsi
Sep 23, 2004
beloit, Wisconsin
Why is it recommended that you replace the auto tensioner when u do a timing belt? Is it really necessary? My engine has 144xxx miles on it if it matters.
Thanks
Brandon
What he said. It's job is to keep tension on the belt. If it doesn't do that properly the belt becomes loose and teeth slip causing all sorts of delightful damage. Usually just bent valves and nicked pistons....nothing big.
I'd replace the idler pulley as well... Especially if it's still the original... The bearings have to be pretty worn at this point and a seized idler will kill your timing belt and subsequently your top end just as quick...
And if you still have them the balance shaft belt as well...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
