Timing Belt Alignment Mark Check
Zoned
Jan 18, 2014
Napa, California
I wanted to make sure that I have the alignment marks correctly in place. Hopefully, someone could give me some feedback.
I torqued the pulley and tensioner, waited an hour and everything seems to be in better alignment now.
I can't seem to find the torque specs for the idler pulley in the Haynes manual. Do you not torque this bolt?
I'm in the process of placing the crankshaft pulley. I used a longer bolt and I was able to get it on almost all the way, but it's not completely locked in place yet. Should I place in the stock bolt now and torque it, or do I need to keep cranking on the longer bolt until the pulley is completely in place?
The FSM shows the factory torque specs of all pulleys. The marks look spot on. When I did my timing belt job I was off a tooth my first try and it sounded terrible but a 420a won't bend valves if off just a tooth so don't stress about it too much.
