ECMlink Timing all over the place
seattleshawn
148
Feb 7, 2010
Edmonds, Washington
Well I know less than nothing about tuning. I'm just trying to get a baseline set so I can get my car to someone who knows what the are doing. Here is my first log. what the heck is going on with the timing and what do i need to do here. This is all the longer the car will run. Notice the injector duty, it drops to 0 after a couple seconds. What would cause this?
did you watch any of the video on ecmlink?
might want to start there, they explain your basic setup.
ASSUMING everything is functioning properly and no leaks and such, initial setup is actually pretty easy.
I had a hard time getting mine to idle right until i found out that I had a small boost leak. after that it idled rock solid.
I just did a quick glance at your log and might want to check your fuel setting first. im showing 1500cc and on e85? doesnt match what you have in your mod list but maybe you havent update?
and read the sticky on here too.
