timing advance ground.
2000gtxer
May 26, 2004
calgary,
I was just wondering, I want to adjust the timing. All faqs say ground the timing advance. On a mitsubishi galant 4g63 n/t motor what wire do i ground? Is it on the harness to the CAS? Please help.
Also if you know the answer, can i get the wiring diagram for it.
Thanks :dsm:
i got no clue for your car. on a 95 , there is a wire in the f/w .
on a 1g i think its yet in another place.
i do no , it isnt a wire in the CAS plug.
-Look for a male connector that has a blank female connector as a cap along the main harness on the firewall, usually's located near the center.
