Time for new turbo
TurbofiedTSI
Jul 23, 2009
brohard, West Virginia
Well I recently met up with nate from tpg tuning (team pump gas) and anyways long story short my bullseye to4b turbo gave out. Ton of shaft play and quit building boost completely. Recent owner said he had the same problem and had it repaired under warranty once. Turbo was never set above 18psi...
Anyways Im looking for a quick spooling turbo that will support around 300 hp. Which of these 3 would you guys suggest? Genuine mitsu td05h small 16g, td05h big 16g or evo 3 big 16g? I already have 660 injectors, 255 fuel pump, mbc, ecu+ etc. I plan on adding some 264 or 272 cams later.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Mitsubishi Industries
