PsiRemix
- 92
- 0
- Aug 12, 2004
Kalamazoo/Grand Rapids,
Michigan
I have read and searched almost, if not all the threads trying to find an answer, with no luck.
I recently installed a used Evo3 manifold with an external 38mm Tial flange on the #1 runner that the previous owner had welded together. The manifold also has an EGT bung that was drilled and welded fairly close to the wastegate flange. During the install, I noticed that the divider in the collection area right before the turbo had a crack on each side. I heard Evo mani's aren't prone to cracking, and I figured it wasn't really a threat
so I bolted everything up.
I usually am not the person to buy a used manifold, but I got a great deal on it.
Everything was fine, although once everything was on, I noticed there was a very noticeable "ticking" sound emitting from the engine; especially upon acceleration. Idle is fine, the sound is just very apparent around about 2k rpm. I figured on the speculations about "lifter-tick", but this being my 4th 4g63 vehicle, I know all about "lifter-tick". This sound is quite a difference. Not so much a knocking, but more of an amplified "clicking". In fact, I almost sure that at idle, my usual "lifter tick" is gone.
Can those cracks be the reason for this sound? I just am worried about it being a bigger problem than I anticipate. I also noticed a pin-sized exhaust leak where the EGT bung had been welded on.
Sorry to ask a question like this when I should just take the manifold off, replace it, and see if the problem persists; but I don't have the funds at the moment to buy a brand new one with an 38mm flange, and I am in the process of finding another manifold, and having someone weld a flange on. Plus its my daily driver right now!
Thanks in advance for the help!
so I bolted everything up. I usually am not the person to buy a used manifold, but I got a great deal on it.
Thanks in advance for the help!Attachments
