Tick sound engine off
YoYo_4G63
187
4
Sep 5, 2008
Carolina, Puerto Rico
So after i turn off the engine or simply turn it at the damper with a wrench, i have a weird tick noise coming from the head:hmm: Engine is new, gsc s2 cams, gsc springs and revised lifters. The engine doesn't makes the typical tick noise while running.
Are you sure that it's not lifter tick? Did you check the oil level? What kind of oil are you running? A quick vid could probably bring more answers.
Sounds like a case of tappet noise, which is common on hydraulic lifter motors when they lose their lift due to lack of oil pressure - a bit of clatter until pressure is built back up when starting.
Course, you've got a modified head with larger cams and larger opening 3G lifters that demands more oil to function, thus I would begin to get used to it.
-DSM
My car has been doing this for as long as i remember. A few minutes after it shuts down at temp it makes a few audible clucking noises. I assumed it was something with the hydraulic lash adjusters cooling.
