Tial 38mm big enough for SCM6076BB??
Wicked96GS-T
415
8
Jun 23, 2004
Midlothian, Virginia
Hey guys, it's me again. I have a SCM6076BB with T04S cover that will be going in my built 95 GSX, and I need to know if a tial 38mm is going to be good enough for this turbo. I will be running upwards of 30psi, and the gate is mounted on a SBR manifold.
I have a tial 38mm gate with a sc61 turbo (gt40 compressor wheel), and I have ran 15psi before without a problem.....30psi shouldnt be a problem at all.
i'm running 35mm 0.7bar spring rate Tial off O2 housing with my scm61 and boosting at 1.7bar daily and there no problem at all. What you must look into is the spring rate and plumbing/dump tube of the wastegate.... with less spring rate(0.3bar) the wastegate start to leak during hard acceleration before reaching full boost which slower the spool :notgood:
Thanks guys, that was the information I was hoping to hear. I couldn't find any information on how much power the Tial was good up to. Now I just need to trade out these 650cc injectors for something much larger.
