throw out bearing problem
Lookin4aDSM
40
Aug 30, 2005
Boyertown, Pennsylvania
Hey, I put 60 miles on my car and completely shredded TWO throw out bearings. What could be causing this? pressure plate/Disk? thanks Zach
do you have all of the bearings surrounding the 'throwout bearing' and all the washers...etc. or is it in backwards??
What kind of clutch you runnin? If you are using an act or something that requires a particular step on the flywheel and its out of spec, it will shorten the life of the clutch and tob. Its basically a disengagement problem.
oh yea? hmmmm, i geuss I should go get it checked when i get it resurfaced. its supposed to be between .608-.610 right? correct me if I'm wrong
