throttlebody compatibility?
MrHunter2
Apr 2, 2004
Phoenix, Arizona
What thottlebodies are compatible with the 96 eclipse gs N/T? Any help would be appreciated. Im getting sick of the eratic idle.
I'm not sure I understand what you're asking but here goes. You wanna swap your tb right? You can either swap another one from 420a, swap one from jeep ( there's a LOT of threads about this) or you can have a billet tb build for you ( expensive). Idle surge isn't always because of faulty tb or sensors.
Yeah I figured it could be a few different things. Im starting with the sensors though. I recently cleaned the throttle body because of the idle surge, and it made the idle mush smoother. But now when the car starts cold the idle is very rough. It smoothes out after it warms up though. But on occasion a CEL has gone off. I need to get a scanner to check the code but Im trying to do some research beforehand.
I havent been able to locate a thread on the site (due to being a newcomer to the forums) that specifically lists the compatible parts.
Im new to the DSM world. Im making a switch from Hondas.
