throttle stop switch?
901gclipse
31
Jul 20, 2004
charlotte court house, Virginia
How can i check this to make sure its working I cant find anything on this in the vfaq
If it's not working you will get a CEL when you close the throttle. Normally it starts after the engine is hot unless it's really gone or the wire is broken. If that's not good enough you can also try to test it with an Ohm meter to see if it passes current when closed.
