Throttle Body Upgrade time
icemanracing
85
Feb 8, 2009
Lawton, Oklahoma
I am Needing to go up to a 75mm Throttle body. Problem i have is I have a Forrester intake and it has the DSM Bolt pattern. My question is who makes the best Throttle body available for this. I can get a wilson manifolds one but it is a ford pattern. Do they make an Adapter for this With out having to buy the throttle body with it like the boomba one has?
As a last resort, Steve Monroe can take the stock TB and go 65mm with it, even shave off the front shaft for extra flow (I've been running a 66mm shaved for about 3 years now).
I run an S90 on my JMF intake. It's 70mm with no taper and all I had to do was to port the inlet hole on the manifold to suit.
PM me and I can let you know where I bought mine from if you think it will do the trick for you.
Exactly unless you plan on making like a 700hp+ or run 8's I dont see why the 70mm s90 should be more than you would need or just get a ported 1g throttle body and help with the driveability
yes i'm going for over 700hp. the throttle body, M&W Pro 14 ignition, and 5 bar map sensor should be all that is holding me back. Thanks for the replys i will be checking on the S90 thanks.
