Spyder Throttle body swap
Why do you want to swap it? If you really want to do so, you could swap to a 1g N/T throttle, the bore is slightly larger but keep in mind you need to remove and bore out the intake manifold as well to match, otherwise you're just making a step in the air path that will create horrible turbulence.
I already have mine ported but want to go to a bigger throttle body . Not sure yet which direction i wanna go either turbo or Nitrous
How can i swap out my 4g64 throttle body and what other throttle body can i use ? I heard of people using mustang throttle body or jeep throttle body
Im going to ask also. Why? There is zero benefit.
