Throttle Body Sizing
1g 60mm
2g 52mm
2g NT ??? I don't think it will work
420A TB (4g63 NT TB has this extension as well and would eliminate the TB elbow)
4g63 TB
It seems like a different bolt pattern
the 1G NT throttle body is the same diameter as a 1G turbo TB, except the NT has a partition to clamp a coupler on it.
Keep in mind the 1990 1G turbo TB is also available and it only has 2 vacuum ports. Not important if you aren't running your emisison system, but it is important to some. It is also a 60mm.
a 2G NA TB will not work because it is designed for the 420a intake manifold, not a 4G63 manifold.
