Throttle Body Question
tylersevo
576
281
Jul 12, 2011
Lexington, Kentucky
Curious to see if anyone else has gone this far with their 1g/2g throttle body....I had the rubber caps on it for a year or so but got tired of looking at those. Also going with a complete FIAV block plate. The holes are getting welded up and then the whole thing is getting painted.
Nice the screws on my throttle body we totally siezed so I ended up just biting the bullet and getting an S90 70mm.
The only thing I had an issue with was the lower stud the first couple of threads were stripped. I used a tap to clean everything up. I am also going to use a slightly longer bolt to replace it just to be on the safe side. The TPS fit like a glove. I ported the intake manifold to match the throttle body last night. If you go this route i would definitely buy a good grinding bit. The grinding stones will take you a lifetime.
I port matched it to the TB. 70mm. The only issue i ran into was the throttle position sensor hitting the stock fuel rail. I shaved the rail down for it to clear and it was good to go. I didnt have any issues with the throttle cable. So far so good
I will try to post some pics for reference.
Thanks. I have a 90 and a aeromotive fuel rail so I am looking at going this way
I havent test fit any other fuel rail options but i am interested to see what works with the stock intake manifold s90 tb route.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
