This is what I have whats next to get?
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
Has on the car.
HKS turbo timer.
HKS intercooler pipes
Boost gauge
Oil PSI gauge.
The guy i bought it from says it has diffrent cams + im not sure
It has the blue top injectors. not sure if thats stock or not
2 3/4 exhaust
and my mbc is on its way.
I want the motor to be able to hold 18-20 lbs on the strip Im currently running 14 lbs.
I plan on getting 264 cams while I do them im doing a new steel head gasket and timing belt with water pump. and light weight pullys.
I only want to spend about 1 -1500 after that what should be the next things?
SAFC 1st or logger?
Im not sure if im going to get a oem clutch or get a clutchmasters clutch.
But then you need to have a tuner to adjust for all of that right?
Yes you need something to tune it with. The logger will tell you if your tune can be more aggressive, if it is just right, or if it is too aggressive.
