This is what I have whats next to get?
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
Has on the car.
HKS turbo timer.
HKS intercooler pipes
Boost gauge
Oil PSI gauge.
The guy i bought it from says it has diffrent cams + im not sure
It has the blue top injectors. not sure if thats stock or not
2 3/4 exhaust
and my mbc is on its way.
I want the motor to be able to hold 18-20 lbs on the strip Im currently running 14 lbs.
I plan on getting 264 cams while I do them im doing a new steel head gasket and timing belt with water pump. and light weight pullys.
I only want to spend about 1 -1500 after that what should be the next things?
SAFC 1st or logger?
Im not sure if im going to get a oem clutch or get a clutchmasters clutch.
Logger before the SAFC and you need fuel mods before you can turn the boost up that high.
Do you think if i rewire the pump and get bigge injectors that could handle that or should i get a new pump and fpr?
i want to run low 12's i DO NOT want to hit 11.999 because im not puting a cage in my car.
Get a fuel pump. I would get 650's. If you don't want to spend the money on them get stock evo injectors which are 560's. Also get a wideband. I believe you have to run 11.49 or faster to be required to have a cage now. I know they changed the time to a lower one because of all the factory cars that were able to break the previous time.
+ a fpr. what do you think the cost on those would be?
PIMking said:
Injectors pump and wideband?
Around $270 for new 650's. Around $80 or $85 for the fuel pump. And you can find widebands that are new on ebay for $200 or so most of the time. The evo injectors I have found for $35 but that was from a friend. If he knew they were for somebody else he would have wanted $50 for them.
You should go ahead and get the 255 lph pump and fuel pressure regulator. If you dont, you'll be ripping out your 190 later to replace it. Go ahead and get it done.
well im going to start out by this Im going to do the timing belt with a steel head gasket and exhaust many gaskets with new cams and cam gears with underdrive pullys then im going to go with a fuel pump fpr and injectors. then wideband and logger.
I picked up a brand new safc2 and wideband combo for 450 bucks, just couldnt pass that up. Got some friends in high places if you know ### i mean.LOL
Don't do AFC, just get the dsmlink. That's what I did and it was stupid. If you plan on doing any extensive mods in the future you'll need dsmlink.
yeah im waiting until friday to buy a logger. I do not have the mbc connected and im running 15-16 psi with no fuel cut yet. It was running 14 psi until I timed the car now its at 16 and pulls hard.
the only thing a logger does is tell you how the car is running right?
