thicker oil question temporary
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
Car puffs smoke pretty sure its the valve stem seals, and I have to pass emissions within the next month, Would i be able to temporarily put some thicker oil in just to pass emissions so it doesn't puff smoke during the idle test @ 2000 rpm?
Not going to necessary say just adding oil will make you pass, but I always run 20w50. If you do fail post pic off the sheet they give you we can tell you why you most likely failed. I always run emissions no cat, 20w50 and e85 I have always passed. zso you must have something needs looked at pretty decently if you dont pass emissions for being pretty much stock. A fresh oil change, new spark plugs and a nice hard run on the freeway right before you pull into emissions always does justice.
thanks for the reply, I didn't mean if i ran different oil it would make me pass emissions, I was wondering if thicker oil would help seat the worn valve stem seals so it didn't puff mad crazy while idling whiling waiting/ performing the emissions test.
edit: I am currently running 10w30, and it recently started puffing within the last 4 days or so.
My first sentance LOL :p I said you can try to add some thicker weight oil but not saying that is going to be your answer for passing emissions. Depends on what the sheet shows when you get the results.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
