These Boost Gauges
SPYD3R
82
Oct 25, 2005
Austin, Texas
You're only saving about 20-30 dollars by going to Lotek.
I've had great results with Faze gauges -$45 +/- 30
And autometer costs a mere 50-55.
I was looking at Extremepsi.com and I found some autometer boost and vac gauges frr about $70. I do want mechanical if I am just connected to the hose with the t-fitting.
I have the VDO boost gauge. I love it. It reads accurately and lights up well. I got mine from extrememotorsports.com along with their install kit, which, considering other people's problems installing other boost gauges WITHOUT a kit, this makes everything super easy.
VDO (black face)
Install kit
Gauge= $45 + Install kit= $10
That's a pretty good deal. Heck, even if you don't go with this particular gauge, at least get the install kit and save yourself the trouble of using the crappy, kink-prone nylon tube that comes with every gauge.
Thanks, that was helpful.
I think I am going to get a VDO gauge, with that installation kit, then I have to get a A-Pillar, which I think I am going to get from Lo-tek. What is another necassry gauge to have?
EGT, and maybe oil pressure or water temp. The good news about the guage pods is, if you get the 2 1/16" (52mm?) guage size (I'm pretty sure that's the size that the VDO boost guage is), you can buy camera lens caps that fit in the hole perfectly and cover it. So if you don't fill all two or three holes right away, you can cover the others up and still have it look nice. I've got one left to fill, as soon as I can afford an EGT gauge.
Thats great advice... good job bud :thumb:
And because I'm a nice guy (and have nothing better to do on a Saturday) I took some pics of how the Lo-tek looks with the VDO boost gauge, another gauge, and a lens cap covering a hole, just to give you an idea.
Don't be afraid to spend a little money, after all this is your engine you're monitoring. I saved some cash by going with Autometer, but all in all I like the setup.
I'd like a black face that luminates as well. But the lumination I'm seeking is just the numbers and dashes. I love the red lighting like our stock 2g gauges look.
