thermostat housing connectors
thetech0922
111
Oct 26, 2010
Piedmont, South Carolina
Ok here is the issue i have a 1g and most of the connectors are broken are missing. I still have the tabs that the connectors slide onto on the housing. There are two right together one vertical and one horizontal (i broke the connector somehow when i was putting the wiring harness back on :banghead: ) which color wire goes on which one. Then i have one to the far right of those two..what color wire goes to that one? And lastly i have one that goes on the back side of the thermostat housing too? It would be amazing if i could get a picture of this..and if not just tell me which wire goes where?? I am within a few hours of starting this thing and this is the only issue that is holding me up:ohdamn: thanks guys
We need pics to be specific i know what you mean but the wires colors the yellow and green go to the vertical and the black and green one are to he horizontal.
I have just the connector for the two that are together...problem solved. Now i need to know what the connector to the right of those two are and there is still one on the backside....i will try and post a picture in a lil while
