the only way to go
bulletproof96
Mar 4, 2007
houston, Texas
ok a friend of mine just let me have a turbo, downpipe, exhaust manifold, intake manifold, waste gate, b.o.v, boost controller, side mount intercooler including all the lines and ic piping all that came from his 91 turbo talon. I have a 93 eclipse 2.0 non turbo and i've been reading and researching on how you have to change one of the cams on the non turbo engine, buy stronger pistons, buy a turbo thorttle body, turbo ecu + wiring harness etc. In order to turbo my car is that the only way to go with the parts i already have or can i just slap these parts in with some good fuel injectors and good engine management and call it a day? what do ya'll think.
I think you should sell all of those parts and buy a 4g63
That was pretty shitty advice.
Im no expert with na's turned to turboed. Im pretty sure you need all the extra stuff you needed. If you already have the 4g63 engine, then you can pretty much follow the build ups everyone else is going buy. Get the stuff you listed but also you will need fuel and a way to control it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
