spooled_u_1st
- 332
- 17
- Aug 27, 2006
Pittsburgh,
Pennsylvania
Ok well if your going to stick with a 7 bolt the swap is very straight foward so it shouldn't be to hard on you guys. Just make sure you label everything and bag it up.
If it has a cracked block, it probably shot a rod threw the block. Chances are the crank is fubarred too. I did the same thing to my engine 2 years ago but built a 6 bolt from the ground up.
You probably don't need a entire engine. A long block would be easier but you could also get a short block and rebuild the current head.
