#The notorious P0300/302/304 & P0400
805DSM
403
6
Jun 10, 2005
Oxnard Shores, California
1st and foremost, yes i have searched and read other threads and have used alot of info from them and still nothing.
SPEC'S
1999 Spyder GST
STOCK 7Bolt & Cam/Crank Sensors ,Stock plastic ECU WITH BC272 int/exh cams.
Ok ive been dealing with this damn missfire for a while , its Usually a p0300 but there and there i get a cylinder 2 & 4 missfire. I've allready done a Compression check wich came out good at above 180+ all accross , changed transistor/coils/cam angle sensor/plugs/wires and still nothing . I also got a egr code p0400 and i've replaced the solenoid, checked all vaccum lines &egr and it still on . Would the cams or the egr malfunction have anything to do with the missfire? Or would it end up being the crank sensor, im also Running some RC injectors and ive read somewere that they end up going bad, any help will be appreciated .
Try this, put the GM MAS in draw-through and recirc your BOV, or try a known good stock MAS. I'm assuming all your tuning compensation has been done with the SAFC instead of the MAFT?
Yea , i have the maft zero'd out and all the tuning on the safc. Ok ill try that see if it works. Thanks
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
