the correct way
DSMinn0vati0ns
193
Sep 26, 2004
Budd Lake, New Jersey
i have a magnus intake manifold and there is no where to hook the PCV valve up to it like on the stock IM.. what should i do to elliminate the valve and so that im not affecting the engine by not letting it release the air pressure inside.. thanks
Hooking it up to a catch can is the right way. Either hollow out the PCV or get a replacement fitting the thread into the valve cover. This will allow your motor to breath properly.
Steven
No. The valve in there will just spin. You have to cut it in half and remove all the internal pieces. Then figure out how to put it back together. We brazed the one on my mirage together.
Steven
Or you could tap the valve cover (where the PCV screws in) 1/8" NPT. Then you can adapt it to whatever type and/or size hose you need to use.
DoyoFCT said:
Actually if you just take a spare 1g intake that's laying around, or even a 2g maybe there should be a vac fitting on it, that threads right into the valve cover. That's what i did :D
Yep the Vacuum port/fitting that the PVC valve connects to on the intake manifold, is a perfect fit for the valve cover, and they are the same 1G or 2G.
