Testing fuel injectors
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
Is it possible to test fuel injectors completely and clean them as well as I could when sending them off?
If I can only be 90% sure that my injectors are good at home, I'd rather not waste my time since I am troubleshooting a difficult issue.
Please don't ask what the issue is. Don't want to get off topic.
Thanks!
Do you have a way to flow tets them? So if you want to test them there must be a problem? Unless you have the tools to test them i cant see how you could if you didnt send them off to a company like fic to test them. Are you in doubt that there is a problem. Are they new, or used?
Yes, chasing down a problem. Link is below.
No, I don't have a way to check for flow.
Injectors are used. Got them here from a trusty member and they have worked well for about 10k miles as a test.
Since I can't get help with my other post for some reason, I guess that I have to check each individual fuel and spark related item out.
http://www.dsmtuners.com/forums/newbie-forum/461336-misfire-backfire-5k-rpm-lower-gears-only.html
Haven't tried that....around 2.2 ohms right?
Did you do a resistance test? Aside from that all you can do is flow test them and you said you dont have the stuff so you will have to send them out
