temp gauge does not work
jwahl16
427
3
Oct 26, 2009
Havertown, Pennsylvania
my car sat for 5 weeks while i was at college. i came home and the temp gauge does not work. it does not rise from the lowest position. as far as i could tell it wasnt stuck in limp mode so how would i go about fixing/replacing the temp gauge?
so i would have to replace the enitre cluster? do they make aftermarket temp gauges that are easier to install then replacing the gauge cluter
ok thats what i'll do. I have 2 spots left on my a pillar to fill anyway :)
Are there any voltage tests or something i could do to make sure it is the gauge and no the sender that is broken?
Ok, i just got back from school again and i have an update:
I found where the sensor goes in to the water neck and about a foot down the wiring it is just cut/chewed off. I'm guessing something might of gotten in there while i was away, i'm not sure. However, i was looking for the other end of the wire that was cut so i could try and solder them back together or something, but i couldn't find it. Does anyone have a picture, or description of where the wire comes from harness side? If its too hard, i'll be ording a temp gauge tonight!
Thanks
