temp gauge does not work, it hasn't worked since I bought the car
Check your wiring connnector to the temp sensor. If it isn't corroded, try replacing the sensor. If you know someone with the same car, try borrowing his cluster to see if your cluster is still good.
yea my temp gauge doesnt work either i replaced the 2 lower sencers where the coolant goes i need to get the temp gauge sencer from a dealership
